My client has a need that the end users should not be able to take the output of webi, crystal reports by using shift print screen. can you help?
apoorv (BOB member since 2005-08-30)
If you do a Google search for “disable print screen” you will find some techniques. These fall into two categories: 1) Javascript solutions for intercepting a Print Screen action in web pages, and 2) Windows SDK code for doing the same thing in Windows applications. In theory, you could use a Javascript solution if you modify Infoview, but I don’t think you’ll find anything for CR.
Keep in mind, too, that these solutions are only good for disabling Print Screen while the intended application is active. There’s no way (that I know of) to prevent the user from switching to another application and taking a full-screen screenshot.
Of course a scorched-earth approach would be to modify the Windows registry all on users’ machines to full disable the Print Scrn key.
Joe
joepeters
(BOB member since 2002-08-29)
In addition to Joes comments there are many other applications that can perform screen grabs. They would have to prevent direct / download access to these, also.
Mak 1
(BOB member since 2005-01-06)
You’d have to take everyone’s mobile phone away too.
Ian@mcc
(BOB member since 2008-03-12)
[quote:cb6f04c846=“Ian@mcc”]You’d have to take everyone’s mobile phone away too. ![]()
[/quote]
And poke out their eyes, just in case they had rather a good memory.
Mak 1
