We are planning a migration from a hosted BO provider to either another hosted BO environment or an internal one. What are some of the items we should consider prior to the migration? I am thinking of the following:
- Document and reapply Tomcat settings
- Document and reapply BO server settings (is there a quick way to do this)
- There are no customized logos/banners/etc, so we should not have to worry about this
- Using the BIAR file to capture all the content
- Database connections and credentials
Is the above list fairly comprehensive? The BIAR file contains schedules as well if I can recall correctly, correct?
