Portal Integration Kits
In the data sheet for BusinessObjects Developer Suite it says: “Developer Suite provides portal integration kits for the leading enterprise information portals”. What do they mean by that? And is it possible to see an example of a portal integration kit anywhere?
My company is planning on building a single sign on portal where the user gets listed all the documents ha has access to. When clicking on a document this document should be downloaded from the repository and started in BO 5.1.3. Any thoughts about this solution? Is it possible to accomplish?
Any help on this will be greatly appreciated :smiley:
Zaitan (BOB member since 2003-02-19)
BO provides portal Integration kits for many popular portal available from IBM,Microsoft,plumtree…I have used Bo’s portal integration kit with Microsoft share point portal ones and it installs without any problem.
But before deciding on anything,take a look at BO’s new dash board manager…It might be a better option.
dcdas :us: (BOB member since 2002-06-17)
