Hallo
I have some prompt in univers (BO XI r2)and now I want to use the scheduling (with infoview) fonction How can I populate the prompt with a object from the univers?
Pasi (BOB member since 2009-07-29)
Hallo
replace all prompts per predefined filter based on sysdate if it is a temporal problematic
bernard timbal (BOB member since 2003-05-26)
If I replace the prompt in Univers I have a problem with the standar reporting. I use prompt to ddefine a period and booking date depend on the question I have to schedule the report with different values.
And I don’t want to create 2 univers (with and without prompt)
So… create a new temporal prompt and add it to your daily report . If you dont want to show the prompt in the universe then just hide it.
Joe Szabo (BOB member since 2002-08-19)
