I am exporting a Crystal Report to a CSV text file. Some of the fields are blank. Is it possible to populate these blank fields with a Empty placeholder?
Thanks!
Blowers (BOB member since 2009-09-30)
Thanks!
You can create a formula and use it in the report. The formula will be something like:
if isnull(fieldName) or Fieldname=’’ then
else
FieldName
Cheers!!!
Manish
cr_manish (BOB member since 2009-07-30)
Great i’ll try that
Thanks!
