how do we point universe in devlopment to production.can anyone tell me stepwise as i am new to BO.
Thank you
bloome (BOB member since 2005-08-18)
Thank you
First things first, if you are new and unsure about things, back up the universes before you do anything.
Then you need to change the connection of the universe to ensure it is pointing to your production database. This is done as follows:
Now for the export:
Hope this helps…
jac (BOB member since 2005-05-10)
jac’s suggestion works if your development and production universe domains are part of the same security domain / repository.
You didn’t provide information about your repository setup. Do you have a single repository, with development and production universe domains both in that repository?
Or do you have separate repositories / security domains / BOMain.keys?
If so, this entry from our Reporter FAQ has steps to follow to migrate universes and reports if you have totally separate repositories.
Anita Craig (BOB member since 2002-06-17)
