system
September 16, 2019, 3:15pm
1
Dear BO experts,
I am using BO 4.2 and I know that there are several Placeholders to be used in Scheduling:
%SI_STARTTIME%, %SI_OWNER%, etc
Do you know where in the CMC are defined these Placeholders?
Thanksssss
Victor_BCN (BOB member since 2009-09-15)
system
September 16, 2019, 7:36pm
2
They aren’t defined that way. They simply represent the names of properties of the scheduled instance that can be used as placeholders.
If you query for a scheduled instance using Query Builder, you will see all of the properties associated with it. Any of them (except property bags) can be used as placeholders.
Joe
joepeters (BOB member since 2002-08-29)
system
September 18, 2019, 11:55am
3
Hi, thanks for your answer.
My final goal is to create “new placeholders”
Is this possible in BO 4.2?
Thankssss
system
September 18, 2019, 12:46pm
4
system
September 19, 2019, 2:21pm
5
Hello,
I found this SAP Note https://launchpad.support.sap.com/#/notes/1449399
Im gonna have a look, there might be a chance
system
September 19, 2019, 3:17pm
6
Different placeholders. Those are used for server settings, ex. %DefaultInputFRSDir%.
