Pie Chart Issue
I am using Bo 3.1 sp3… I am having an issue building a pie chart.
Say I have EMP, Sal, Sal Total. I need to show pie of only one employee at a time. Now for employee A I need to show pie chart as what is the Sal of the total. So the data looks like this
Empname    Sal      SalTotal
A                500        2000
I know you can not show 2 measures on pie chart…
But still… is there a way… or may be instead of Pie, use some other chart which works best in this case.
any idea…
rajx72 (BOB member since 2006-08-02)
Pie charts are limited to one measure because the values have to add up to 100%. With multiple measures there’s no way to ensure that, thus you can’t use more than one measure in a pie.
But, you might wanna try this solution as it worked for me.
Before you create a chart, think about the story you want to tell. Then consider creating a bar chart over a pie. Pie charts do not really (effectively) tell the story. (In my opinion) I have certainly recently shifted my paradigm.
When you have a few minutes and want to have some fun, you might want to review the “Graph Design test.” It may allow you to rethink your presentations. It did me. http://www.perceptualedge.com/files/GraphDesignIQ.html
An interesting article about our facination with all things circular:
Here is another good presentation on dashboard design. I found it to be very helpful
Here is what SAP says about Pie charts:
“Do not Use it…
For exact comparisons of values, because estimating angles is difficult for people.
For rank data: Use column/bar charts in this case; use multiple column/bar charts for grouped data
If proportions vary greatly; do not use multiple pies to compare corresponding parts.”
Wesley Gibson :new_zealand: (BOB member since 2012-12-19)
Hi Wesley
Thanks for the reply. even i am not a big fan of Pie charts. but the user wants it… since there are only 2 measurs and one Row… the user whats to see Total value and what is the slice for Sal in that…
Bar charts with just 2 bars does not look good.
is there a better way to show it
