Performance Managment & Dashboard builder for XIR3.1
I have installed BO XIR3 and it is working fine and nwo i m planning to install Performance Managment & Dashboard builder. Do we have seperate XIR3 versions for this or will XIR2 versions of Performance Managment can be installed to existing XIR3 version?
bluecarbon :india: (BOB member since 2008-11-08)
You must use XI3.
So we have XI3 versions of Performance Management and Dashboard Builder?
Dashboard builder is no longer a product. It’s part of InfoView. Performance Manager is still a separate install or license. You should talk to support about this, as you may need new keys.
Thanks for your reply,
May i know the version of Performance Management that is compatible with BOXIR3
Well, it’s XI3… It’s included in the base server installer.
The version has to match the version of BOE.
You really should look this stuff up on the support site.
As a side note:
Performance Management is end-of-life…
Thanks for all your guidance. Atlast i m able to make my Dashboard and Analytics to work without error in Infoview.
But now i m not able to see any thing or blank after clicking both these components through Infoview.
Open -> Dashboard And Analytics
Open -> Dashboard And Analytics Setup
I m using IE8. Kindly provide some inputs to resolve this issue.
Hi bluecarbon,
We are facing the same issue, Were you able to resolve the error. if yes, Can you please provide some guidance on how to resolve it.
Appreciate your help.
friend (BOB member since 2006-07-03)
Hi friend,
Try this,Open IE
go to TOOLS—>Compatibility View Settings—>then add your BO url or check the “Display all websites in CV”. Close the window, restart your browser
Saikrishna
saikrishnag21 :india: (BOB member since 2011-02-10)
