BusinessObjects Board
perfomance: number of tabs in LO webi document
I’ve got a question concerning the performance of my xcelsius dashboard.
Does it matter if the SWF needs to extract the data from a webi document containing 10 tabs or (let’s say) 20 tabs.
Anyone experience on that?
Tiny :netherlands: (BOB member since 2004-11-10)
Well, yes. It shouldn’t make a huge difference in a well-tuned environment. But all of those tabs do have to get processed by the system in order to return the data you are looking for.
Also as a note, pulling multiple blocks from a single report can create significant issues, particularly if you are refreshing with prompts.
