I have a small issue with the PDF. In crystal report viewer the report is displaying properly with lables and data. When I convert it to PDF, the lables and data are not displaying properly. Some items are not displaying, some items are moving to other places.
If I do some work in crystal report to display the things properly, but in crystal preview it is not proper.
Please let me know, if there is any solution for this.
Are the symptoms due to Fonts shrinking?
If so, I saw somewhere on the web that by editing a registery key, it can be solved… Try searching for it… if I find anything, I would get back…
They all say similar things to try, but the last one is the one I ended up using. Please note the change they are suggesting be made is one that needs to be made on the server, not the client. Also, I’ve tested this for version XI 3.0 and the registry change works there as well (the links are only for version XI 2). HTH.
