Patching 4.3 sp3 hung /hotfix
I was able to successfully patch my dev box, but of course prod hung on starting the SIA. I am pretty sure it installed everything, shows as installed in control panel, but I can’t get it to gracefully complete.
Any tricks to force that install to look complete, if only to uninstall and try again? If I tried and deploy the war file successfully, think I can just declare victory?
Brent
  • old time BOB user, great to find this again!
did you check the licence?
BI 4.3 needs a new licence key.
after apply, you need to enable servers in CMC
hope it helps
Support convinced me that it was ok, so I manually deployed and it seemed fine. Find out next patch
B
