Is it possible to passing variable between report and report?
example… a document contains summary & detail report… when I drill down at the summary page how can i pass those drilled values to detail report and display corresponding data?
Try searching for “linked reports”. Don’t believe this will work in Full Client without some VBA, but you might be able to get something working on the WebIntelligence side.
