I am able to pass parameters from my sub-report to my main report but only if the sub-report is not suppressed or not hidden. I don’t want to see the sub-report when I run the main report - just the result of it. Any ideas? Thanks!
Gingerly (BOB member since 2011-03-24)
Figured it out - made all fields white font/white background and changed size of sub-report to .2 all around. Hope this helps someone else!
Don’t use subreport for calculate one value! Your report will be very slowly… Better solution in this way is to use sql expression.
- Field Explorer | New
- Type sql statement in brackets(!), for example:
(select sum(sallary) from orders where customerId = {customers.customerId})
Hope this helps!
sulmar (BOB member since 2012-05-18)
I would love to try this, Sulmar but my NEW is grayed out in Field Explorer. How do I activate? Thanks!
