Passing a List of the Top 10 Values from Main to Sub - How?
I have a report that gives me a list of customers sorted by Time frame (A) and by Measure (D) and I need the Top 10 value to be passed to a sub report through a Parameter so it can generate a reduced result set. I am able to pass the first value but nothing else and the Parameter doesn’t see it. I have 3 arrays statements in the main report. The first one is in the report header and looks like this:
//Customer Array Reset
whileprintingrecords;
//Declaration of Array and variable for counting
global StringVar Array CustomerArray;
global NumberVar Customer_counter;
//Re-dimension of Array and initialization of variable
Customer_counter := 0;
The second one is below the first:
//Customer Array Accumulate
//Incrementing the variable for counting
Customer_counter := Customer_counter + 1;
//Reading values in the Array with the Array Index as variable value
CustomerArray[Customer_counter] := Database_field
And the third is in the report footer:
//Customer Array Append
//Using the Join Function to concatenate using delimiter
Redim CustomerArray[180];
Join (CustomerArray[1 to Customer_counter],",");
What am I doing wrong?
fknaut :us: (BOB member since 2005-08-04)
What section is your subreport in?
-Dell
