BusinessObjects Board
parent/child flash
What am I missing? I have 4 dashboards all at the same “level”. I pass a location via a flash variable and launch the next dashboard via a radio button.
Now I’m adding a 5th work area/dashboard and I can’t get the “child” dashboards to load from it. It’s 18 months since the first 4 went live and I can’t remember what I did. I launch dashboard, click another work area and nothing happens…
  1. I have a radio button that selects the work area
  2. I have a hidden url component for each radio button selection that triggers when the corresponding option is selected. The url loads a second dashboard and passes the location via a flash variable
I’m missing something obvious but can’t remember what it is! :crazy_face:
Debbie
Interesting…
It’s to do with the visibility of the url component. If you hide it with dynamic visibility, it doesn’t fire, even if it’s triggering on an event and not on a manual click.
Once I made it visible and just hid it behind another component, it worked fine.
Another lesson learned.
Debbie
we should write a book :slight_smile:
Cairmor :us: (BOB member since 2008-06-05)
