BusinessObjects Board
Parameter Column Sorting
I want all the columns in classes and objects folder to be sorted. I ahve changed the parameter [COLUMNS SORT] to Yes. still i don not see the columns in order.
Anyone can you please help me ?
Asmitha
Asmitha :uk: (BOB member since 2008-06-06)
There is no automatic way to sort classes and objects. You can do it manually, or you could try doing it with a VBA script.
COLUMNS_SORT:
Determines the order that columns are displayed in tables in the Structure pane.
Yes: Columns are displayed in alphabetical order
No: Columns are displayed in the order they were retrieved from the database
And all that gleaned from the HELP file :roll_eyes:
Peter Hughes :uk: (BOB member since 2005-11-21)
Asmitha,
Have you tried search? I think this problem has been discussed on BOB many times. For instance, the recent occurrence is here:
Original post said:
Help file said
Those are two different things.
Yes Dave, I got confused… Sorry about that and Guys, Thank you all for you help.
