Paramaters keeping changing back to Allow Custom values=True
I have a Crystal report with Parameters that come from a Universe.
The parameters are set to constrained and when I set them up in Crystal I change Allow Custom values=False.
It seems like whenever I change one of thes parameters in Crystal they all change back to Allow Custom values=True
Also even if they are correct it Crystal when i deploy them to Infoview they still display the Custom part of the parameter as well.
Anm i doing something wrong? Is this a bug?
Bruce
bjf :new_zealand: (BOB member since 2006-04-19)
hi,
Have you changed the universe parameter value from free to constrained or the Universe parameter was intially created as “Constrained” itself.
You can try removing the parameter from the report layout and then again include the parameter into the report…
-Sherine
Sherine :india: (BOB member since 2009-02-10)
It was originally set to neither free nor constrained, ie the last part of the @prompt was blank. We added constrained to try and fix this problem.
I’ve removed and readded the parameters from the report multiple times already.
Bruce
http://homepages.woosh.co.nz/bf/
