How can we use the components inside the panels. It is allowing for another SWF and Jpeg images. I want to develop a dashboard with 10 dials to show. Dials should be grouped across 3 categories.
Panel set looks good to use, since they allow a selected category of dials to occupy entire screen space ?
You should be able to drag the component(s) onto the panel. Make sure the component is inside the panel, and not on top of it… Make the component smaller if necessary.
