I am having performance problems using outer joins in DI, to build temporal data sets.
I am trying to collapse a number (5) temporal tables into a single temporal table. This is a technique i have used on a number of different tools.
I outer join the tables on their natural keys, and then join using ‘between’ on the dates on all the points of change ( using a union/pivot of all the ‘date_from’ from the source tables ).
I then use a self join ( outer ) on the natural key to the ‘next date’ row, update the ‘date_to’.
When trying to do this in DI, I am having performance problems with the outer joins. It seems to do a cartesian and then filter! I have 3million rows in the intermediate table. I had to abort at 300 million rows.
By eliminating all DI functions and using just surrogate keys using the temporal dates, I can get it to push down ( insert /+Append/ select ), and it completes in 5 minutes.
This is flaky though as it sometimes times out on the Data transfers not returning in time!
Any tips, tricks, techniques please ?
Do I cut my loses and just use DI to execute SQL statements ?
Frustrated !
Pat
pxbaker
(BOB member since 2007-01-09)
(BOB member since 2004-01-30)
