OS Users and Groups Report
Hello,
Is there a way to create OS (UNIX/LINUX or Windows) users and user groups report in WebI or in WebI RC? If there is how do you do it? Does this require SDK?
zulu1900 (BOB member since 2005-07-27)
One way is to get list of OS Users through AD or LDAP browser into a xls file.
Then get list of Business Objects CMC Users using SDK file availabile in BOB Download section.
Then use the above 2 xls files as data source for your WEBI report. I use this technique sometimes to get more details such as user’s region, manager etc available in LDAP for a BO user.
shekar25 (BOB member since 2004-05-11)
Shekar,
Thanks for the suggestion. I think pushing OS users/groups in to xls is my one option. I don’t need anything from BI CMC users and groups so I’m ok on that.
I’ll also ponder little more to see if there is any other option available other than xls.
Thanks so much!
[Moderator note - moved to the WebI forum]
the question is where is your data source for this information?
erik.stenson :us: (BOB member since 2012-07-30)
Erik,
data sources will be in multiple places:
  1. first report will be from local server users and groups
  2. second report will be from LDAP users and groups --2nd report
