Oracle roles for data security
In a message dated 99-03-05 16:54:42 EST, you write:
My question is can you automatically
execute a script upon opening a universe?
You can execute a script automatically upon starting or quitting
BusinessObjects, before refresh of a document or after refresh of a
document.
A couple of loop holes to point out:
  1. If the user used the “Tools / Login As…” menu option, there is no script
    (event) that occurs. In other words, someone can log in to Business Objects
    without firing off the “starting BusinessObjects” script.
  2. The refresh script event only gets half of the possible ways of refreshing
    a document. There are six different ways that I have identified for
    “refreshing” data in a report. Only 3 of them are noticed by the
    “OnBeforeRefresh” event. The six ways are:
  3. Run, from the Query Panel
  4. Set the “Refresh on Open” attribute on a document, close it, then open it
  5. Click the “Refresh” button on the toolbar
  6. Select “Data”, Refresh from the menu
  7. Click the “refresh” button from the Data Manager (View Data) screen
  8. execute the “refresh” method via a script
Item 1 (Run) does not get noticed. Which, strictly speaking, is not really a
refresh. However, the “refresh on open” does not get noticed either. That may
be less used. But, and I think that I am doing this correct, the “Refresh”
button on the Data Manager window does not get noticed either!
Only items 3, 4, and 6 are logged by the OnBeforeRefresh event.
Dave Rathbun
Integra Solutions
www.islink.com
