- Can we execute oracle packages in BO reports ?
- Can oracle HINT be used in the creating BO reports using universe.
I don’t want to use free hand SQL.
Sree
gsreeni (BOB member since 2009-11-03)
Sree
You could have used the cool search feature of BOB (in semantic layer forum with keywords: package)
Found one here
haider (BOB member since 2005-07-18)
The answer to your 2nd question:
Yes, hints can be used. The object with the hint in its definition needs to be the 1st object selected in the query panel.
…or defined in the Connection parameters, which would apply the hint to any query that uses the connection.
joepeters (BOB member since 2002-08-29)
