We are upgrading to 4.2.9 and installed ORACLE 11G version.
Created a datastore with Oracle version as 11G and ran a simple job to test. The job writes to a template table. When I run the job I get the following error:
error message for operation : <ORA-00933: SQL command not properly ended.
I tried looking for solutions and tested many different things but not able to find the correct solution for this. Any help is appreciated.
This was a DBA issue when switching Oracle 9 to Oracle 11. Though our DB was technically upgraded to 11, there were some issues. So Oracle 11 query was running on Oracle 9 DB version and it generated the error as mentioned.
When DBA CORRECTED the issue, our issue was resolved.
