Oracle 11g based application can connect SAP BI4.3
Hi Experts,
We are in process of migration from SAP BI 4.1 to 4.3. We are having Oracle 11g based applications that connects BI 4. Once we migrate these connection will work or not? Is SAP BI4.3 support Oracle 11g connection? Please advise.
Are you asking if SAP Supports an external application built on Oracle 11g accessing Business Objects or are you asking if SAP BI4.3 can use Oracle 11g as a data source for universes?
I haven’t looked at the Supported Platforms document for BI4.3 lately but I would assume that there is support for Oracle 11g as it isn’t that old.
Yes, I am asking SAP Supports an external application built on Oracle 11g accessing Business Objects or not? In PAM guide of BI 4.3, Oracle 11g is not mentioned.
SAP does not support 11g because it is EOL.
“Maybe” it will technically work but I wouldn’t bet on it.
With 4.3 SAP has removed a lot of old sources.
As per the PAM weblink below, Oracle 11 is supported by BO 4.3
https://support.sap.com/content/dam/launchpad/en_us/pam/pam-essentials/SBOP_BI_43_Supported_Platforms.zip
