ORA-3113
Hi Team,
I have a report which is not working and gives ORA-3113-end of communication file error and the other reports are working fine.
Please help me out… :hb: :reallymad:
Sai
saikrishnag21 :india: (BOB member since 2011-02-10)
The ORA-03113: end-of-file on communication channel error is a generic error. The ORA-03113 error when connecting suggests that the connection was established, but lost later, like a timeout.
There are many possible causes for the ORA-03113 error. It is a “catch-all” type error which means “I cannot communication with the Oracle shadow process.” This usually happens when the Oracle server process has died for some reason.
For example, ORA-03113 could be signaled for any of these scenarios:
Server machine crashed
Your server process was killed at O/S level
Network problems
Oracle internal errors / aborts on the server
Client incorrectly handling multiple connections
etc… etc… etc… - a lot of possible causes !!
How do I fix this ORA-03113 error?
Answer: Use the oerr utility to get the details for the ORA-03113 error:
Cause: The connection between Client and Server process was broken.
Action: There was a communication error that requires further investigation.
First, check for network problems and review the SQL*Net setup.
Also, look in the alert.log file for any errors.
Finally, test to see whether the server process is dead and whether a trace file was generated at failure time.
data_guy :us: (BOB member since 2006-08-19)
Thank You for the reply.
If only one report is not working fine does that mean that there is a problem in the SQLquery of the report.
Sai
