ORA-03106: fatal two-task communication protocol error
I’m working with Business Objects 5.1.5 and trying to connect to several Oracle 9i databases. The development database is version 9.2.0.4 whilst the production is 9.2.0.6.
I can connect to both databases using SQL Plus and I can connect to the development database through BO. However, when I create a connection for production, I receive the following error message:
BusinessObjects configuration:
Network Layer: Oracle OCI
DBMS Engine: Oracle 9
DLL: C:\Program Files\Business Objects\Data Access 5.0\SQBOCI50.DLL
SBO: C:\Program Files\Business Objects\Data Access 5.0\Oracle\Oracle
PRM: C:\Program Files\Business Objects\Data Access 5.0\Oracle\ora7
RSS: C:\Program Files\Business Objects\Data Access 5.0\Oracle\oracle
I looked at a similar posts and tried the suggestions contained within these posts:
Unfortunately, I’m still experiencing the same problem :frowning: . Any ideas?
Thank you
maccers :uk: (BOB member since 2005-06-17)
R,
Have you had a look at this?
https://bobj-board.org/t/23379
It is worth checking with the DBAs if the ORACLE drivers are setup correctly.
Does your underlying table include CLOBs?
http://www.tek-tips.com/viewthread.cfm?qid=967090&page=9
Could that be part of the problem?
Is there anything special about the column that is supporting the object? I can’t get login to see the email you sent me.
SQL*Plus is deceptive as it doesn’t use all the same parts of the stack that BO uses. Try using Toad instead. That is a better indicator of any problems with the Oracle configuration.
Best Regards,
M
robbinma4 :uk: (BOB member since 2005-07-31)
Hi M,
I did and revisited the link shortly after posting this note. I think my connection problem is potentially related to the NLS_NCHAR_CHARACTERSET parameter, so I’ll explain at the bottom of this response.
Checked with the DBA and he said no.
I don’t think this is applicable and don’t worry about the e-mail as all is contained within.
Works on both TOAD and SQL*PLUS.
So getting back to the possible problem, one difference between standard Oracle builds within the company and this problem database (production)is the NLS_NCHAR_CHARACTERSET parameter setting.
I can connect to Oracle databases where the parameter is AL16UTF16 but not when set to UTF8 (production).
My guess is that 5.1.5 isn’t compatible when the NLS_NCHAR_CHARACTERSET parameter is set to UTF8 (unicode)? I’ve asked that this parameter be changed to AL16UTF16, so I’m just waiting on a response.
Thanks M, I’ll get back to you once I hear more…
Best Regards,
R
M,
Found the solution:-
5.1.5 isn’t compatible when the Oracle NLS_NCHAR_CHARACTERSET parameter is set to UTF8 (unicode). The Oracle DBA changed the parameter to AL16UTF16 and the connection now works.
R
