ORA-01481: invalid number format model :-1481
I’m getting this error msg:
with this sql from a Filter I created in Designer:
SELECT FEDERAL_EFFECTIVE_DATE
FROM FED_DEDN
WHERE to_number(FEDERAL_EFFECTIVE_DATE, ‘YYYY’) = @prompt(‘Enter Tax Year’, ‘n’, , mono, free)
I tried using to_char also, but the query just hung.
Any suggestions?
Thank you,
Bob
BobL (BOB member since 2002-08-29)
Try:
FROM FED_DEDN
WHERE to_number ( To_Char (FEDERAL_EFFECTIVE_DATE, 'YYYY') ) = @prompt('Enter Tax Year', 'n', , mono, free)
Just a note… I think you may also want to consider using: ‘’ for the list of values. This makes sure that you don’t ever that the LOV try to build.
The TO_NUMBER(TO_CHAR…)) suggestion by Andreas should work.
-RM
Please, could you eloborate on this one?
If I didn’t want to use a list of values for this object, I could phrase it as:
TO_NUMBER( TO_CHAR( FEDERAL_EFFECTIVE_DATE, 'YYYY') ) = @prompt('Enter Tax Year', 'N', '', mono, free)
The ‘’ means that it doesn’t pull the list of values from a Class or Object, therefore you never really have a LOV for this prompt.
-RM
And why would you put in the empty single quotes for the LOV parameter in the @prompt instead of just leaving the parameter empty :?:
TO_NUMBER( TO_CHAR( FEDERAL_EFFECTIVE_DATE, 'YYYY') ) = @prompt('Enter Tax Year', 'N', , mono, free)
Ah…
I do that out of habit. BO used to have problems with the parameter being left blank. I don’t remember which version, but it was one of the early 5.x versions. I have done it both ways, but the double single-quotes have had a more consistent behavior for me.
-RM
Digpen, thank you for the insight :slight_smile:
