Ora-00920 Invalid Relational Operator
Does anyone have any idea why this condition should cause an
Ora-00920.
@Select(Accounting\Go) IN @Prompt(‘GO: ‘,‘A’,‘Accounting\Go’,multi,) OR
@Select(Accounting\Go)LIKE
UPPER (’%’ ||@Variable('GO: ')|| ‘%’) OR
@Select(Accounting\All Acctg) IN @Variable('GO: ')
mvbokker (BOB member since 2002-09-03)
Try removing
UPPER ('%' ||@Variable('GO: ')|| '%')
from your condition/sql. Does it run now?
If so check out the thread “case insensitive prompt
