ORA-00917: missing comma in bods script
I am using script in bods 3.2 for this i created one Batch_control table in oracle database and i insert global varilables in job level
Here is my global variables
$SYSDATE DATE
$CDC_DATE DATE
$BATCH_END_DATE DATE
$BATCH_NAME VARCHAR(25)
And my Batch_control table format in oracle is here
Batch_name varchar2(25)
Batch_status varchar2(10)
Batch_start_Date Date
Batch_End_Date Date
Load_Date Date
in script i implement below commands
#SET TODDAYS DATE
$SYSDATE = cast( sysdate( ),‘DATE’);
print( 'TODAY DATE IS: ’ || cast( $SYSDATE ,‘VARCHAR(24)’));
#SET CDC_DATE
$CDC_DATE = nvl( cast( sql( ‘ODS_DS_TRG_ORACLE’,‘SELECT MAX(BATCH_END_DATE) FROM DS_TRG.BATCH_CONTROL WHERE BATCH_NAME = {$BATCH_NAME }
AND BATCH_STATUS='SUCCESS'’),‘DATE’),cast(to_date(‘1900.01.01’,‘YYYY.MM.DD’),‘DATE’));
print( ‘CDC_DATE IS:’||cast( $CDC_DATE,‘VARCHAR(24)’));
#MAKE AN ENTRY IN BATCH_CONTROL
#BATCH_NAME BATCH_STATUS BATCH_START_DATE BATCH_END_DATE LOAD_DATE
sql( ‘ODS_DS_TRG_ORACLE’,‘INSERT INTO VASU_DS_TRG.BATCH_CONTROL VALUES ({$BATCH_NAME},'STARTED',[TO_CHAR($CDC_DATE,'YYYY.MM.DD')],NULL,[TO_CHAR($SYSDATE,'YYYY.MM.DD')])’);
#PRODUCT_DIM STARTED 1900.01.01 2013-12-09(SYSDATE)
when I validate this script its not shows any errors but when I run this script I has been getting below error.
4844 6008 RUN-050304 12/10/2013 11:57:45 AM Function call <sql ( ODS_DS_TRG_ORACLE, INSERT INTO DS_TRG.BATCH_CONTROL VALUES
4844 6008 RUN-050304 12/10/2013 11:57:45 AM (‘PRODUCT_DIM’,‘STARTED’,1900.01.01,NULL,2013.12.10) ) > failed, due to error <70301>: <Oracle error message for
4844 6008 RUN-050304 12/10/2013 11:57:45 AM operation : <ORA-00917: missing comma
please help me to solve this issue
:hb: :hb:
Venki
ursfriend77 (BOB member since 2011-03-02)
If the columns will be DATE in the Oracle DBMS, then I bet the below should be your INSERT Script
sql( ‘ODS_DS_TRG_ORACLE’,‘INSERT INTO VASU_DS_TRG.BATCH_CONTROL VALUES ({$BATCH_NAME},‘STARTED’,{$CDC_DATE},NULL,{$SYSDATE));’);
Another side note, you are doing too many conversions, it is not nice to have too much conversions too, it basically drags your execution time.
Hi Ganesh,
Thanks for your response,I used in my script what you mentioned
sql( ‘ODS_DS_TRG_ORACLE’,‘INSERT INTO DS_TRG.BATCH_CONTROL VALUES ({$BATCH_NAME},‘STARTED’,{$CDC_DATE},NULL,{$SYSDATE})’);
but i have been getting below error.It is very crucial to me convert oracle datatypes.
5068 5392 RUN-050304 12/10/2013 1:20:12 PM Function call <sql ( ODS_DS_TRG_ORACLE, INSERT INTO DS_TRG.BATCH_CONTROL VALUES
5068 5392 RUN-050304 12/10/2013 1:20:12 PM (‘PRODUCT_DIM’,‘STARTED’,‘1900.01.01’,NULL,‘2013.12.10’) ) > failed, due to error <70301>: <Oracle error message for
5068 5392 RUN-050304 12/10/2013 1:20:12 PM operation : <ORA-01861: literal does not match format string
venki
Got you…My bad…Below should work i believe.
sql( ‘ODS_DS_TRG_ORACLE’,‘INSERT INTO VASU_DS_TRG.BATCH_CONTROL VALUES ({$BATCH_NAME},‘STARTED’,TO_DATE($CDC_DATE,‘YYYY.MM.DD’),NULL,TO_DATE($SYSDATE,‘YYYY.MM.DD’))’);
Thanks Ganesh,
what you mentioned about i tried it before,but i was getting “Invalid character error”
Here
sql( ‘ODS_DS_TRG_ORACLE’,‘INSERT INTO DS_TRG.BATCH_CONTROL VALUES ({$BATCH_NAME},‘STARTED’,to_date($CDC_DATE,‘YYYY.MM.DD’),NULL,to_date($SYSDATE,‘YYYY.MM.DD’)’);
Error is
5752 2448 RUN-050304 12/10/2013 2:12:37 PM Function call <sql ( ODS_DS_TRG_ORACLE, INSERT INTO DS_TRG.BATCH_CONTROL VALUES
5752 2448 RUN-050304 12/10/2013 2:12:37 PM (‘PRODUCT_DIM’,‘STARTED’,to_date($CDC_DATE,‘YYYY.MM.DD’),NULL,to_date($SYSDATE,‘YYYY.MM.DD’) ) > failed, due to error <70301>:
5752 2448 RUN-050304 12/10/2013 2:12:37 PM <Oracle error message for operation : <ORA-00911: invalid character
Venki
please help anyone on this issue. I am troubling here.
Venki
Wrap the DATE variables with {} and it should work I believe. I don’t have an Oracle system to try it out here.
