Optional Prompts are now mandatory pompts after converting
We converted CR 2008 reports(Manually) to CR enterpirse version after converting CR 2008 reports with optional prompts are now Mandatory prompts , can you let us know how to over come this?
Note:DB used is oracle and the CR rpeort is based on SQL query
babu_272 :india: (BOB member since 2010-07-28)
I don’t have a copy of CRE available to check, but have you looked to see if there’s an “Optional” property for prompts in CRE? If there isn’t, then you might try to see if you can set a default value for them. From there, instead of using “HasValue” to determine whether the prompt was used, you would just look for the default value in any formulas where you’re using the prompt.
-Dell
