Opening AfO document ends in error (WIS 99999
Hi all,
When I try to open a document in a newly installed BO 4.3 system, it ends in error. We have configured the resful webservices on the SSL port 443, so I dont understand why it is asking to be open on the port 6405 ?
I have also configured the ssl port (443) in the axis2.xml file in C:\Program Files (x86)\SAP BusinessObjects\tomcat\webapps\dswsbobje\WEB-INF\conf
Any ideas ?
16:34:39.092 |INFO |AoPlugin | Cause of exception: GetServerInfo exception (Error: WSE 99999)CauseMessage: Une erreur s’est produite lors de la rĂ©ception de la rĂ©ponse HTTP Ă  http://nans01958.it.intra.sercel.com:6405/dswsbobje/services/Session. La raison peut en ĂȘtre que la liaison de point de terminaison de service n’utilise pas le protocole HTTP. Cela peut Ă©galement ĂȘtre dĂ» au fait qu’un contexte de requĂȘte HTTP a Ă©tĂ© ignorĂ© par le serveur (peut-ĂȘtre Ă  cause de l’arrĂȘt du service). Pour plus d’informations, consultez les journaux du serveur. #
16:34:39.115 |INFO |AoPlugin | Logon with parameters → CMSNAME: , WSURL: http://nans01958.it.intra.sercel.com:6405/dswsbobje/services/Session #
16:34:39.145 |INFO |AoPlugin | Exit CheckBoeSystem #
16:34:39.177 |ERROR |AoPlugin | Error checking BOE system: #
16:34:39.208 |INFO |AoPlugin | CommandProcessor: Main Command: com.sap.ip.bi.pioneer.core.command.launchWithFile State: End ExecutionResult: False Information: #
16:34:39.305 |INFO |AoPlugin | End Launch with file #
16:34:39.337 |DEBUG |Cof | Trying to delete launcher file:C:\Users\admin\Downloads\ASzKlB706Y9BsEwKu2Xld_E.sapaox #semantic-layer-universe-designer
Thanks in advance,
Have you check the configurations in the CMC → Applications:
  • Restful webservices
  • Web services
I think that these are still configured to use the Web Application Container Service (that runs by default under port 6405)
Thanks for your reply.
I had not configured the Web Services application to use the https port.
It works now.
