Does the latest version of Lumira support OpenDocument? If so, does it work both ways? Can you open Lumira via WebIntelligence/Crystal Reports/X-Celsius and can you open those via Lumira?
Anyone come across this yet?
indy (BOB member since 2004-04-08)
You can do OpenDocument from anything mate (I`ve done it from CRM system etc in the past!).
What do you mean specifically?
ABILtd (BOB member since 2006-02-08)
Indy, the short answer is Yes. Now if your thinking of passing paramaters then each tool-to-tool will behave differenetly.
katullus (BOB member since 2009-08-21)
