OpenDocument hyperlink removes data
I’m trying out report linking for the first time and when I add in the opendocument code it removes the contents of the fields.
I’m following these steps:
  1. right click measure cell, hyperlink > new
  2. then create the following code:
http://server:8080/wi/bin/iswi.dll/WIGenerator/wigenerator/ generator/OpenDocument.jsp?sDocType=W&iDocId=2865&sRefresh=Y&lsSEmployee=[L01 CRM Employee Long Name]
The data then is totally gone, checked it wasn’t just the font that had changed. The formula window now shows ="".
I’ve used the following sap article as a guide:
http://www.sdn.sap.com/irj/scn/go/portal/prtroot/docs/library/uuid/f0daee1d-0e38-2d10-0c91-8bb4ab5aa266?QuickLink=index&overridelayout=true
Am I going about this all wrong?
ally3009 :uk: (BOB member since 2010-08-10)
Check out my 2nd reply in this post. I’ve explained how to create Open Doc in detail.
M H Mohammed :us: (BOB member since 2010-06-16)
That’s a lot easier! Strangely my earlier search didn’t bring that one up. Many thanks for the prompt response s well.
