system
October 6, 2009, 4:53am
1
We have used opendoc syntax in hyperlink (format field) of a field in Crystal report.
this is the syntax used:
"<href=../../../../../../opendoc/openDocument.jsp?sIDType=cuid&iDocID=Abl2zciArzJPv2pkvkYqDtY&sType=rpt
When we view this report in Infoview the URL is framed correctly and the target report is opening.
URL: http://<server>:<port>/businessobjects/enterprise115/desktoplaunch/opendoc/openDocument.jsp?....
But when the Crystal report having the hyperlink syntax is being called from an application using crystal viewer SDK, it is not framing the URL properly.
URL: http://<server>:<port>/businessobjects/opendoc/openDocument.jsp?....
Any help or suggestions to correct the same is appreciated.
thanks
ravi
palepuravi (BOB member since 2003-10-28)
system
October 6, 2009, 4:58am
2
In XI R2, try this as the relative path for openDocument
../../opendoc/openDocument.jsp? ...
[/code]
Farhan Jaffery (BOB member since 2005-08-27)
system
October 6, 2009, 5:13am
3
Thanks for the reply, I did try that syntax for relative path. But, when i try that both in Infoview and through application is not framing the URL correctly.
URL is framed as below:
Infoview:
http://<server>:<port>/businessobjects/enterprise115/desktoplaunch/InfoView/plugin/crystalenterprise/report/opendoc/openDocument.jsp?
Through Application:
http://<server>:<port>/businessobjects/enterprise115/desktoplaunch/viewers/rpt/opendoc/openDocument.jsp?
any alternate way to match the folder path it traverses to find the opendocument.jsp??
thanks
ravi[/code]
