This is my first time trying to use open document so I’m hoping someone can help me out.
Not sure where I should put the name of the report or where it’s located if I have to do that. I put the doc ID in the syntax.
The report is in My Favorites/HHG Report and the name of the report that I want to link to is TLPaid. I also want to pass the value of Tid to the linked report.
Invalid identifier ‘a’ at position 15. (WIS 10022)
When I remove the = and the quotes I can apply the link. But when I run it I get the following error:
404 Missing Page
The page you requested is not available on this web server for one of the following reasons:
The address you typed may be inaccurate. For example, a character was missing. To correct this issue, double-check the address and make sure that it is spelled correctly.
If you clicked on a link or button, the web application that generates this link may be experiencing a temporary problem. Close and restart your browser and try the link again at a later time.
