only supports locales using UTF-8
SunOS 5.9
XI R2
Logged in as Root
Copied all folders (DISK_1, DISK_2, DISK_3) to disk.
Create a user XI
Su XI (login as xi)
cd /…/DISK_1/
Running installation ./install.sh
and it outputs:
BusinessObjects Enterprise currently only supports locales using UTF-8
encoding.  Please change your locale
to one using UTF-8 encoding and try again.
Thank you for choosing Business Objects.
Exiting...
I tried: setenv LANG en_US.UTF-8
…but does not help. Is there an other way to work around this problem ?
kilko :norway: (BOB member since 2006-01-27)
It looks like the install script checks locale in the following order… This if from an older install script - I don’t have SP2 downloaded.
# figure out which local encoding to use
encoding="$LC_ALL"
if [ "$encoding" = "" ]; then encoding="$LC_CTYPE"; fi
if [ "$encoding" = "" ]; then encoding="$LANG"; fi
So, also check your LC_ALL and LC_CTYPE first and possibly change them also?
Here’s what happens on my test - solaris
$ locale
LANG=
LC_CTYPE="C"
LC_NUMERIC="C"
LC_TIME="C"
LC_COLLATE="C"
LC_MONETARY="C"
LC_MESSAGES="C"
LC_ALL=
$ export LANG=en_US.UTF-8
$ locale
LANG=en_US.UTF-8
LC_CTYPE="en_US.UTF-8"
LC_NUMERIC="en_US.UTF-8"
LC_TIME="en_US.UTF-8"
LC_COLLATE="en_US.UTF-8"
LC_MONETARY="en_US.UTF-8"
LC_MESSAGES="en_US.UTF-8"
LC_ALL=
So, I’d check LC_ALL - maybe that is different.
Good luck,
Patrick
Patrick McDonough (BOB member since 2002-08-20)
i’m using /bin/sh
$locale
LANG=
LC_CTYPE=iso_8859_1   (NORWAY?)
LC_NUMERIC="C"
LC_TIME="C"
LC_COLLATE="C"
LC_MONETARY="C"
LC_MESSAGES="C"
LC_ALL=
LANG=en_US.UTF-8: is not an identifier
How can I get around this ?
…okey, I found that I just have to switch shell…
Like switch to BASH, and I can then use the EXPORT command - and it worked. :wink:
