Once SAP Dashboards is gone, what should users use? What are you telling your users to migrate to?
pcgeekus
(BOB member since 2003-10-16)
pcgeekus
I think the only option if you stay with SAP is SAP Analytics Cloud. I have looked at the trial version and watched a number of videos. Pretty impressive.
A large number of Xcelsius and SAP Dashboards customers have also moved across to Squirrel365 www.squirrel365.io
It has a 30 day trial and if you email support they will also switch on a labs XLF convertor.
Cheers
Mark
p.s. full disclosure, I work for Squirrel365 as I loved Xcelsius and when I found Squirrel I just had to be part of the team
An easy way to makes webi able to be your favorite tool for dashboarding is the Need4Viz addon need4vis site . Many customers having Xcelsius and SAP Dashboards are able to replace their dashboard by combinating webi and Need4viz
It has a 30 day trial.
Cheers
Jérôme
