We are using WebI 2.7.3 connecting to MSAS 2000, Service Pack 3a. When I go to Create Documents --> OLAP data sources in WebI, the connection to our Analysis Services server says:
Status: Connection Failed
Connection attempted to: PRODOLAP
Error Number: 20
Error Description: Unable to connect. Possible causes: Authentication, Insufficient Privileges, Server is Busy, or Server is not connected to network.
But the reports that use the very same connection are working fine! Any ideas? I suspect a security problem, but since my group doesn’t have direct control over the Analysis Services or WebI server, I can’t experiment until I have something specific to try.
Jen
jenhanson (BOB member since 2004-01-16)
