Object Naming in Upper case
I am dragging my table into the universe window, which will create my class and objects based on that table.
I want all my object names in upper case. I am just thinking instead of manually we typing all object names in upper case, if there is any feature with the designer, which we can achieve that
Somtimes it takes time if we have lot of objects
Let me know
BOLearner (BOB member since 2005-01-20)
No, there’s no feature in Designer that would accomplish this.
Thanks Michael
don’t you think, BO can/should add this feature in designer
Michael, wouldn’t you be able to manage this with a strategy alteration? That’s where the Initcap and the transfer of _ to " " takes place… seems you could try removing the Initcap function or even replace it with an uppercase function.
Dave, I’ve never tried that. I assume that would be an external task, not something that would be done within the Designer application, right?
Here is an Excel macro for mass updating universe names. Download the default names, change them to upper case in Excel, then upload them.
Dennis W. Disney :us: (BOB member since 2003-09-17)
