Numeric Formatting Problem
Content-Description: “cc:Mail Note Part”
 Hi All
 I'm sending this on behalf of colleague of mine.
 Marcel
______________________________ Forward Header __________________________________
Author: “Jason Kinnear (Salome Van der Watt)” VDWattS2@telkom.co.za at
INTERNET
Date: 1999/03/18 10:00 AM
Hi Listservers
When exporting a universe we get an error “The universe could not be
exported. Please rename the universe name and filename”. You then have
to manually delete the universe from Supervisor and then do the export.
If I rename the universe I and
continiously export it, it works fine.
We are using BO 4.1.3 and the database is Oracle 7.3 with SQL Net 2.3.
Please help…
Marcel Visagie
Attachment converted: Macintosh HD:RFC822.TXT (TEXT/MSIE) (000113E0)
Approved-By: thompson@POBOX.UPENN.EDU
Date: Wed, 17 Mar 1999 10:11:53 -0800
Andrea,
Are you using Webi (2.0.1)? - it solves a lot of problems with the
formatting of numbers in Webi (2.0).
Cheers
Graham
Andrea wrote …
We are having a problem formatting some of the data we have in a WEBI
report.
… all number that formerly appeared like with a two decimal place
extension
(e.g. 7.00) should now appear as an integer (e.g. 7)
… 3 numbers which continue to appear in the 0.00 format.
Andrea Riley
ariley@citgo.com
