in boxi rel 3.1 is there a webi setting which turns numeric fields from nulls to zeros?
Bell_33 (BOB member since 2010-07-05)
You can just use the standard cell formatting…it allows you to specify the format for positive, negative, zero and null…so put a 0 in the null box and off you go.
Nick Daniels (BOB member since 2002-08-15)
Nick, that has not worked, please can you outline the steps involved…Thanks
Nick, works…
Cheers
undefined = null box
Cheers
Not working for cross tables, though, which is very regrettable. BO is not very user-friendly here …
triangulum (BOB member since 2011-10-21)
Hi u can use this formula
=if(isnull([object]);0;[object])
i will solve ur problem very easily…
babu_272 (BOB member since 2010-07-28)
Yeah but I would have to store the formulae in variables (since they are accessed once in the condition check and another time in the not-null case).
Since most of my formulae are now directly entered in the cells, I was looking for a more economic way.
Then I came across a hint from Estonia …
The cleanest solution would still be if the number formatting allowed to display “0” for null values in case of cross tables, too.
In the crosstab cell, try:
0+[Measure / Formula]
HTH
mcnelson (BOB member since 2008-10-09)
It works for me in a crosstab in XI 3.1. I just created a custom format of 0;0;0;0
Debbie
Debbie (BOB member since 2005-03-01)
