Hello, I got a strange thing. Probably easy one for somebody. I just realize that when I open an xcelsius which I created in a earlier version of SP2 in new sp2, I just cannot see all the components which is available in SP2. By example, all the gauge object. Any idea.
I used a trial version for now. But if a create a new file, I see all the new objects…
One possibility is that you are not looking at the same Theme. Some themes (Nova and Halo I think ) have more components than the other themes.
This is due to the complexity of programming fancier components in the flashier themes. Themes control your component set.
For example…the Nova theme has more gauges and dials to choose from than Admiral. Unless something has changed in the past couple months, your trial version has nothing to do with this. You get all themes in the trial.
