Not in operator
Hi guys,
Need your help.
I am creating DESKI report where i have to write forumla that give me count of products where type not equal to Book.
I have to create variable as
=sum()where( <> “Book”)
But issue is as soon as i write
=sum()where(, after this i dont see any other operator except = OR See list of Values. I am not sure why <> is not showing up.
I am trying different way as welL:
=If(<>“Books”) then sum(), it throuws computational error.
Thing is in this case i see operator <> but not in above case.
Any help guys how to resolve this?
karan_aries (BOB member since 2005-02-17)
With Deski you can only use = in an “In” clause and then only when compared to a dimension object. The easiest way to solve your question is you remove the <> calculation and put it in another variable.
You can see an example in the Reporter FAQ in this post. :slight_smile:
Thanks that worked. :stuck_out_tongue:
