Not able to view data from SAP application datastores
Dear All,
I am facing the following issue with SAP DS 4.2 SP3.
I have connected successfully to SAP ECC 6.0 box using SAP DS. I am able to import tables from SAP. But when I right click and go to view data, I am not able to see any records. Also, if I go to profile tab, I am able to update the number of records in the table and see the profiling information such as min/ max/ distincts/ nulls etc. And I am able to see results in the column profile tab too , which shows the distinct values in a particular column.
If I use this table as a source in a normal dataflow and extract into a staging table, I end up with 0 records (although the table has 5000 + records).
The data flow doesnt fail.
Any thoughts as to why i am not able to see data in the table imported in SAP applications datastore and why 0 records get extracted ?
If I do use the table in a R3 dataflow, then I am able to extract all the records.
Thanks[/img]
sram83 (BOB member since 2014-12-12)
