Not able to send IDocs to SAP
Hi, We are on DS 4.0. We are migrating data to SAP CRM. We are using BPDM for this. We successfully tested and sent Prospect using IDOC type CRMXIF_PARTNER_SAVE_M02 with message type as CRMXIF_PARTNER_SAVE_M. Now we need to send some custom fields. Custom fields are added using AET in SAP CRM. So we extended the existing IDOC Message type and created a new Message type. We used BDFG to do that.
When we user WE19 to test this new iDOC then it updated all fields fine. Now I imported this iDOC in Data Services. I used the existing Qry-Nest transform ( which was successful with old IDOC) and mapped the new custom fields.
I did made update in global variable to include this new IDOC Type and Message Type. When I send iDOC then it fails in DS with error message
IDoc target could not add IDoc <> to SAP link:<
IDoc error: Message : Error when calling IDOCTYPE_READ_COMPLETE:RFC_ABAP_EXCEPTION-(Exception_Key: OBJECT_UNKNOWN,SY-MSTY:E, SY-MSGID:EA,SY-MSGNO: 447)
IDoc Type
Release: 702
IDoc Number: Not applicable
Segment Name: Not applicable
Segment Type: Not applicable
Field Name: Not applicable
Architect2009 (BOB member since 2005-10-26)
Can you search this forum for the term IDOC, please? I remember I have posted a response from my developer and he was saying something like “run this function module manually to figure out the root cause”. Was it the function IDOCTYPE_READ_COMPLETE maybe? Probably.
I am facing similar problem. But not able to find the solution in the forum. Can any one help me.
c_rajendra_79 (BOB member since 2013-01-21)
please go through the below link:
http://www.riyaz.net/sap/beginners-guide-to-ale-and-idocs-a-step-by-step-approach/18/
ankit2 (BOB member since 2012-08-17)
Hi Werner ,
I am trying to load data into SAP for Functional Locations Domain using the ‘FUNC_LOC_CHANGE’ IDOC in Data Services and I am getting the following error.
8236 7776 R3C-244005 2013/02/27 4:52:36 PM |Data flow DF_ChangeIDOC|Loader FUNC_LOC_CHANGE01
8236 7776 R3C-244005 2013/02/27 4:52:36 PM IDoc target tried to generate IDoc <FUNC_LOC_CHANGE01> from NRDM data: <
8236 7776 R3C-244005 2013/02/27 4:52:36 PM IDoc Error: Message: CIDocIterator::Field: No datarecord available for this segment type
8236 7776 R3C-244005 2013/02/27 4:52:36 PM IDoc Type: FUNC_LOC_CHANGE01
8236 7776 R3C-244005 2013/02/27 4:52:36 PM Release: 731
8236 7776 R3C-244005 2013/02/27 4:52:36 PM IDoc Number: Not Applicable
8236 7776 R3C-244005 2013/02/27 4:52:36 PM Segment Name:
8236 7776 R3C-244005 2013/02/27 4:52:36 PM Segment Type:
8236 7776 R3C-244005 2013/02/27 4:52:36 PM Field Name: FUNCTLOCATION
8236 7776 R3C-244005 2013/02/27 4:52:36 PM >. Check your input data.
6992 8284 R3C-244005 2013/02/27 4:52:46 PM |Data flow DF_ChangeIDOC|Loader FUNC_LOC_CHANGE01
6992 8284 R3C-244005 2013/02/27 4:52:46 PM IDoc target tried to generate IDoc <FUNC_LOC_CHANGE01> from NRDM data: <
6992 8284 R3C-244005 2013/02/27 4:52:46 PM IDoc Error: Message: CIDocIterator::Field: No datarecord available for this segment type
6992 8284 R3C-244005 2013/02/27 4:52:46 PM IDoc Type: FUNC_LOC_CHANGE01
6992 8284 R3C-244005 2013/02/27 4:52:46 PM Release: 731
6992 8284 R3C-244005 2013/02/27 4:52:46 PM IDoc Number: Not Applicable
6992 8284 R3C-244005 2013/02/27 4:52:46 PM Segment Name:
6992 8284 R3C-244005 2013/02/27 4:52:46 PM Segment Type:
6992 8284 R3C-244005 2013/02/27 4:52:46 PM Field Name: FUNCTLOCATION
6992 8284 R3C-244005 2013/02/27 4:52:46 PM >. Check your input data.
I am trying to update the ABCIndicator from 2 to 3 and hence have set the Flag to X in the source table as well. I have updated the EDI_DC40 mandatory schema with the necessary values and mapped the values to the schemas in the IDOC
E1FUNC_LOC_CHANGE - from the source table
and sub schemas
E1BP_ITOB - some from the source table and other values to NULL
E1BP_ITOBX - FLAG X to the ABC Indicator from Source table and all others to NULL
E1BP_ITOB_FL_ONLY - NULL for Everything
E1BP_ITOB_FL_ONLYX - NUll for everything
I have tried to play around the FROM cluase in the query as well as UNnesting…all of them failed to resolve the issue…Can you please suggest me where I am going Wrong…
Chan
BOConsul :canada: (BOB member since 2005-01-12)
Yes, very likely the From clause. Why don’t you write the data into an XML template object or an IDOC file for a test, this will show you that the CHANGE01 structure has zero rows because of From/Where clause for this schema in the query.
Thanks for your reply…>can you let me know how i can write it to an IDOC file…
also a quick question, Do I need to have a seperate query for each segment or can it come from a single source.
