I am trying to promote my Crystal reports from PROD to TEST. This is a new engagement and they were doing everything in prod and no reports in test. So i am trying to make the process of promoting from test to prod. All i am doing is i am grabbing a few rpts at a time and trying to promote them. But i keep getting this error
Resolution Status=Copied, Dependency Status=Some of the required dependencies are not selected., Commit Status=Commit is successful., Promotion Status=Warning: Can't apply override; Override Information is Not Available
I have googled and googled but i cant seem to get past this. I am trying to update the over ride settings but i dont see anything in there when i go in over ride settings. No connections, nothing. Any help is greatly appreciated. Thank you.
If i am not wrong you must be using the Promotion Management within CMC? When you select the reports that you want to promote, There is a button which says Manage dependencies, did you check all the dependencies for those reports?
Hi Chetan, i am actually moving them from PROD to TEST so that i can sync my TEST Env with PROD. I am not selecting any dependancies because i do not wish to bring any schedules along with the reports. I do not see any connections in the dependencies though. Thank you.
I am stuck all most in the same situation. I moved my reports from PROD to QA, Reports got moved fine to QA but the connection is pointing to PROD. I did not select any connection during my promotion.I tried to change it manually but no luck. Please help
I have more than 100 Crystal Reports, each report is connected to multiple tables and I have sub reports too in couple of reports, which are connected to multiple tables. As SAP suggested to use override settings in Promotion Management, which at a place overrides all the connections at one go. I tried to implement the same but no luck. Please suggest do you have any other options.
