system
1
Dear All,
We are trying to extract Data from ECC table - COAS, which is table class view.
Can you please let me know if Data Services has any restriction on such ECC tables
PS: I am able to import the table, but not able to view the data from Data Services designer ( as we have checked Data at ECC end)
Data Services Version = 4.2 SP02
OS = LINUX = RHEL 6.3
Thanks !!
sjain
(BOB member since 2009-04-17)
system
2
Sandeep, did you get any issues or error messages while loading?
ganeshxp
(BOB member since 2008-07-17)
system
3
As said before, all table types can be read from (see Load data from SAP cluster table)
What exactly is the problem you are facing?
ScSi
(BOB member since 2013-10-08)
system
4
Please send the screenshot of the error you are getting to know more about the issue.
Siva Namagiri
snama (BOB member since 2015-02-18)
