I created one xcelsius dashboard using Quaaws it is working good with the source file, but when I am trying to export it to ppt or flash it is not showing any thing
Please help me out!!!
Kriti
Kitts (BOB member since 2010-01-08)
Kriti
After exporting … open in ppt and press F5 then it will ask two options … then select the second option i.e., Enable this content… then it will display what you are expecting…
surya.g (BOB member since 2009-11-24)
Thanks a lot Suresh I did not know this as I am very new with xcelsius.
But, now one new problem occured, when I am opening the same file with powerpoint, is giving error as #2170, and it is working fine with xcelsius soure file.
Can u please help???
Thanks in advance.
Best Regards
Kriti
Please upload the screen shot…
Attached the screenshots for the error I am getting. FYI I am having one tabset in my xcelsius dashboard, consisting of two tabs. when i click ok on the error territory tab is working and the detail tab is not displaying any data.
This screenshot displays both the scenarios.
Thanks and Regards
Kriti
Error#2170.zip (134.0 KB)
Surya G, Many thanks - I too was caught out with Powerpoint not displaying the Xcelsius doco. But hitting F5 did the trick. Your tip is greatly appreciatied!
Great Advice
Pugs.
Pugs (BOB member since 2008-03-18)
