system
July 9, 2015, 6:14pm
#1
When we try to run a job in our PRE PROD which consumes a webservice it is throwing below error.
Unable to create WS-security policy. Ensure that the policy file {1} exists and is valid.
When we are running the same job from our DEV environment the job is working.Our DEV environement is not behind a proxy where as the PRE PROD is.We are using Policy file posted in this forum which worked well in DEV env.When we try to log in axis2_log using -D -np we dont see anything logged.Not even in error log file.The webserivce url is a HTTPS url.Any help on this issue is appreciated
mvkreddy15 (BOB member since 2015-05-13)
system
July 9, 2015, 11:11pm
#2
Did you uncomment and fill in this tag-
The most likely reason you have no axis2 log file is because the job is failing before connecting to the WS
sominya_bajpai (BOB member since 2008-01-24)
system
July 14, 2015, 11:24am
#3
Nope…the proxy is under HTTP un axis2.xml…so will this work for an HTTPS url too?
system
July 15, 2015, 12:36am
#4
Yes it is strange, But it works for HTTPS URL as well.
I have done a similar configuration 4 weeks back.
Basically for HTTPS you need to put the certificate info in the tag -
C:\Folder\cert.crt
and uncomment and put entries in Proxy tag.
When you download the certificate you must download it with chain.
Mozilla Firefox provides the easiest way to download certificates.
system
July 15, 2015, 11:07am
#5
Thanks Bajpai.Now am receiving the below error in axis2_log
Wed Jul 15 13:54:04 2015] [debug] …\src\omxmlsec\axiom.c(129) [rampart]Checking node Password for EncryptedKey
[Wed Jul 15 13:54:04 2015] [debug] …\src\core\transport\http\sender\http_transport_sender.c(246) ctx_epr:https://pr4-18-02.myloadspring.com:443/p6ws/p6ws/services/ProjectCodeAssignmentService
[Wed Jul 15 13:54:04 2015] [debug] …\src\core\transport\http\sender\http_transport_sender.c(805) using axis2 native http sender.
[Wed Jul 15 13:54:04 2015] [debug] …\src\core\transport\http\sender\http_sender.c(416) msg_ctx_id:urn:uuid:1afad130-bba0-4b10-8be3-83bad1cab6e7
[Wed Jul 15 13:54:17 2015] [error] …\src\core\transport\http\sender\http_client.c(238) Error creating a socket. Most probably error returned by OS
[Wed Jul 15 13:54:17 2015] [error] …\src\core\transport\http\sender\http_client.c(239) Socket Creation failed.
[Wed Jul 15 13:54:17 2015] [error] …\src\core\transport\http\sender\http_client.c(544) client data stream null or socket error for host pr4-18-02.myloadspring.com and 443 port
[Wed Jul 15 13:54:17 2015] [error] …\src\core\transport\http\sender\http_client.c(548) A read attempt(HTTP) for the reply without sending the request
[Wed Jul 15 13:54:17 2015] [error] …\src\core\transport\http\sender\http_sender.c(1381) status_code < 0
[Wed Jul 15 13:54:17 2015] [error] …\src\core\engine\engine.c(179) Transport sender invoke failed
[Wed Jul 15 13:54:17 2015] [info] [rampart][rampart_mod] rampart_mod shutdown
